Change system numbers
Discussion in '3CX Phone System - General' started by bundzmm, Sep 12, 2017.
  1. bundzmm
    Sep 12, 2017
    Hello. I need to change system "Echo test" number 777 because one of our managers have same number on asterisk. We want to save old number, most of our clients know it. How can i do it?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    You have not specified what version of 3CX
    Note sure if this will work, in 3CX - Settings - Parameters - Search for echo
  3. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @bundzmm,
    Please do note, that dial number 777 is the PIN protect and as all system extensions it cannot be changed. Also, changing parameters is not a recommended option. What exactly is your situation, what are you trying to do, what version of PBX are you on?
    Thank you
  4. bundzmm
    Sep 12, 2017
    I have 3CX PBX Edition. I had conversation with my boss and that question not actually yet. Thank you.
