Change the default location of the recorded voicemail wave
Discussion in '3CX Phone System - General' started by LiveRock, Jan 21, 2015.
  1. LiveRock
    Jan 19, 2015
    17
    Is there a setting that I can make to change the location of the recorded voicemail wave file and xml?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,117
    206
    Re: Change the default location of the recorded voicemail wa
    Check the custom parameters... If not, it is not likely supported.
  3. LiveRock
    Jan 19, 2015
    17
    I searched and the closest parameter I can find is
    CALLRECORDSROOT
    I guess it is not available or just not documented.
    Anyway, I found another post and used the method; which is creating a symbolic link to it at another location...
    Thanks!
