Solved Change the extension of the operator
Discussion in '3CX Phone System - General' started by Cjackson, Feb 7, 2018.
  1. Cjackson
    Feb 5, 2018
    11
    I set up 3cx as a test environment, we then decided we were happy with it and turned it into a production system, the issue i have is the operator's extension is 000 which just happens to be the emergency services number in Australia, is there any way to change the operator extension or any extension for that matter?
    Thanks in advance
    CJ
  2. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    Hi CJ,
    Go into Settings, PBX Settings. The first option is Operator Extension. Change and select OK. Enjoy!
  3. Cjackson
    Feb 5, 2018
    11
    Worked like a charm, thanks.
    is there a way to change a users extension number or do you just have to delete and recreate?
  4. accentlogic
    Nov 14, 2013
    161
    66
    You guessed right. Delete and re-create.
  5. Cjackson
    Feb 5, 2018
    11
    Perfect, thanks a lot for the help
    accentlogic likes this.
  6. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Glad to see your issue was resolved.
