Change the WEBCLIENTURL Variable in the Welcome Email?
Discussion in '3CX Phone System - General' started by Randall, May 19, 2017.
  1. Randall
    Mar 27, 2017
    30
    17
    I can't seem to figure out where the %%WEBCLIENTURL%% vairable is populated. I figured that I'd see it in the parameters, but it doesn't show up in 15.5.5. Clients are getting the internal IP address in their Welcome emails, but b/c the system is hosted, they need to use the FQDN.
    The code in the email template is below:
    <ol type="List">
    <li>%%IF_TWO_LINKS_START%%Go to %%WEBCLIENTURL%% if in the office or <br>%%WEBCLIENTURLPUBLIC%% when out of the office%%IF_TWO_LINKS_END%%%%IF_ONE_LINK_START%%Go to %%WEBCLIENTURL%%%%IF_ONE_LINK_END%%</li>
    <li>Login using %%EXTNUMBER%%</li>
    <li>With password %%SERVICES_ACCESS_PASSWORD%%</li>
    </ol>
    Thanks!
    Randall
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @Randall
    The welcome email should contain the public FQDN by default as well as shown in the template
    so no manual change is needed.
  3. Randall
    Mar 27, 2017
    30
    17
    The email tells the client to click a link if in the office which is the local IP of the PBX, not the FQDN. Problem is that the PBX is hosted so the local IP is unreachable from the client's LAN. I ended up deleting that entire line from the Welcome email, but it would be nice if one didn't have to alter the template in order to avoid confusion for the client.
