Change to "Music on Hold" not taking effect
Discussion in '3CX Phone System - General' started by jheffernan, Jun 19, 2012.
  1. jheffernan
    Jun 19, 2012
    Hello there,
    I recently setup a 3CX server on a windows 2003 Server. I changed the music on hold to a different .wav file but it does not appear to take effect (even though the Settings..General ..Music on Hold are set to something else.). I have also tried rebooting etc.
    I reinstalled on a fresh Windows 2008 VM and I also changed the music on hold but it still does not reflect the changes.
    Is anyone away of a bug in the latest version (10 SP 6)
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Mine works just fine.
    Did you put your new files in the \Data\Ivr\Prompts folder with a unique name?
    Are they PCM,8Khz,16bit Mono format?
  3. jheffernan
    Jun 19, 2012
    Hello again.
    Yes the file is the "C:\ProgramData\3CX\Data\Ivr\Prompts" directory and is a wav file and is in “PCM,8Khz,16bit Mono format” and the file will even play as a Digital Receptionist prompt but no as music on hold.
    I have changed the setting under “Settings..General..Music On Hold”, and also in “Settings…Advanced..Custom Paramaters .. Musiconholdfile”.
    Is there something I’m missing?
  4. jheffernan
    Jun 19, 2012
    Hello again.
    It appears that once I change a setting ("VOIP Providers" .. "Your Provider" .."Advanced" ..untick "Supports Re-Invite" ) then the correct (and configured) Music on Hold plays.
    Not sure why, but this if this option if ticked it plays some generic Music on hold, if it's un-ticked it plays the configured music on hold.
    Regards Jim
  5. gtsystems
    Jan 13, 2015
    Can someone tell me what software is used to create a PCM,8Khz,16bit Mono wav file for the music on hold
    Gehric
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I wonder if you were hearing some MOH from your provider?
  7. positron
    Jan 14, 2013
    76
    11
    I use Audacity (http://audacity.sourceforge.net). You can either directly record audio or convert from another format.
    To record audio, change the default settings in Edit, Preferences for Devices:Recording/Chanels to 1 (Mono) and in Quality:Sampling to a default sample rate of 8000 Hz, default sample format of 16-bit. When saving the file, select File, Export and Save as Type "WAV (Microsoft) signed 16-bit PCM".
    If converting existing audio from another format, open the file in Audacity, then on the menu, select Tracks, then Stereo Track to Mono (if audio is in Stereo). Then select Tracks, Resample and set new sample rate at 8000 Hz. Save the file using the export option as above.
  8. gtsystems
    Jan 13, 2015
    Thank you,
    That worked perfectly
    Gehric (GT-Systems)
