Change User-Agent
Discussion in '3CX Phone System - General' started by Anonymous, Nov 25, 2006.
  1. Anonymous
    Anonymous Guest
    How do i change User-Agent: 3CXPhoneSystem to something else like
    User-Agent: IM v0.35.2 5.0
    Thank you. This is required by sunrocket in order for it to work.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    User agent
    I assume this is for a VOIP provider?
    Why would they require this, because they want you to use a proprietary client? At present this is not possible, although we will consider it for future releases if there are other voip providers who require this.
