Solved Change User Name?
Discussion in '3CX Phone System - General' started by Peter Richardson, Apr 10, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    193
    7
    Hi there,
    I've just installed and set up 3CX for the first time, but I'd like to change my username to log into the management interface. I'd also like to add a user to the management interface. But I can't find any section relating to users. Is this not an option?
  2. pact
    pact New Member
    Dec 16, 2009
    202
    36
    Hi Peter,
    Admin username is configured under
    Settings -> Security -> Admin Credentials.
    To setup 'other' users, you need to configure extensions to have web management permissions;
    Extensions -> (Pick and extension) -> Rights
    Inside rights, enable 'Allow access to 3CX Management Console'
    Then define which rights you wish them to have.
  3. Peter Richardson
    Apr 6, 2017
    193
    7
    Pact, thank you very much for your comprehensive answer!
