Change voicemail behavior
Discussion in '3CX Phone System - General' started by dustycr, Sep 12, 2017.
  1. dustycr
    Mar 7, 2017
    24
    is there any way to change the voicemail behavior ?
    Currently the caller has to press buttons to record or stop recording the message and also has an option to call the operator.
    Is there an option for just playing a single tone and a prompt saying ,,speak your message after the tone" ?
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @dustycr,
    You can do that by replacing the voicemail prompt with your recorded prompt. So when someone is forwarded to voicemail he/she will hear your message and then the tone. Please do note though, that the options of pressing * or # cannot be disabled.
    Thank you
