Changeing time before phone starts dialing
Discussion in '3CX Phone System - General' started by complea, Feb 21, 2011.
  1. complea
    Feb 1, 2011
    7
    Hi.
    I'm wondering if it is possible to change the time i takes from you have finished dialing before the system puts the call through!? Normally i will dial a number, internal or external, and then i will have to wait for about 6 seconds before the phone starts ringing, unless i press the "dial" button on my Siemens phone then it will start to ring right away. I know this i a timer that has been set as a period where the 3cx system is waiting to see if you are done dialing but 6 seconds seems like quite a while and I know this will become an issue with some customers.
  2. Lukas
    Jan 23, 2011
    45
    Can't answer in general, but with the hardware I use this is set up on the phone, not on the PBX. Once the PBX receives the sip message from the phone there is no need to way as you can't add more digits...
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    It depends on the phone model the exact terminology and where it is placed in the system, but usually configured in the SIP area.
    Look for the Short Interdigit Timer and Long Interdigit Timer. Change the Long Interdigit timer to something shorter but not too short
    The other way is to create a custom dial plan but this can be complicated
  4. leejor
    10,855
    301
    You don't say which Siemens model you are using. I had a look through the manual for S450 IP DECT set. It doesn't appear that that particular model is equipped with facilities to set up an internal dialplan. It does state that you can place calls by dialling the number and then pressing the Talk key, the same way you would on a mobile phone. That should send the call through right away. If you are using a different set, then there may be a similar function.
