Changes to default Polycom VVX provisioning template
Discussion in 'Ideas' started by JonnyM, Sep 6, 2017.
  1. JonnyM
    May 17, 2010
    77
    5
    For some reason the 3CX template for the Polycom VVX includes the following:
    Code:
    call.callWaiting.enable="0"
    call.defaultTransferType="Blind"
    The defaults on the VVX are for call transfers to be consultative, and for call waiting to be enabled. I don't see any reason to change this in the provisioning template.
  2. JonnyM
    May 17, 2010
    77
    5
    Hi 3CX team, I've seen you've recently updated the VVX template but these two config items are still in there. I can't see any way to override this other than duplicating the template and making the changes which then needs repeating for each template update to stop them drifting too far apart. The defaults you've chosen seem to be different to the defaults of the other phones you have provisioning files for.
    I might be missing something here, but it seems like an oversight rather than intentional to have these lines in there. Could you consider removing them?
