Changing 3CX default Registry port
Discussion in '3CX Phone System - General' started by kegler, Jan 19, 2007.
  1. kegler
    Jan 16, 2007
    Is it possible to change the 3CX default registry port of 5060 to another port? I was not able to find this in the configuration or documentation.
    Thanks,
    Keith
  2. Watashi_FR
    Dec 5, 2006
    63
    As far as I know it can't be changed.
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It isn't difficult to do, but why one may need this?
  4. kegler
    Jan 16, 2007
    I would like to have both 3CX and another sip registry running on the same machine at the same time, and to explore the possibility of signaling between the two systems.
    You say that it is possible, how would I go about doing it?
    Thanks!
  5. archie
    3CX Support
    Aug 18, 2006
    1,299
    Yes, it's possible, but it involves program change. Right now, we're not supporting the possibility of alternate SIP port. I'm not sure if we're going to. You may either try to use VM for the experiment you're thinknig about, or try to change SIP port of the "another sip registry".
