Changing avatar icon in Android app
Discussion in 'Android' started by billtodd77, Jun 23, 2017.
  1. billtodd77
    Jun 23, 2017
    Hello!
    I've got a phone that just passed from one user to another. The avatar icon (in the center of the screen that usually says 3CX) for the app is set to the image that the old user used for their Google profile. I've removed that account and added the new person, but the avatar hasn't changed.
    Can anyone help? Thanks!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    58
    Assuming it's like in iOS, then you have to check if you have a device contact (with image) whose eMail address match extension's.
    The logic was simple:
    - you may connect to different PBXes (say one in US, another in Germany), different versions (V14, v15, v15.1) as different extensions, with different mobiles, but you are always the same person, having the same eMail address.
    Hope it helps.
    vali
