Changing Caller Id for internal calls
Discussion in '3CX Phone System - General' started by lsi, Mar 18, 2011.
  1. lsi
    lsi
    Mar 11, 2011
    13
    I'm sure this is something simple that I'm just overlooking, but...
    When we make an external call, the phone number we have designated with our VOIP provider is what goes out.
    Is there a way to use a different number when we make a call (via extension) within the office? So we can tell which extension is calling us?
    Thanks much!
    11,113
    329
    I'm not sure if I have this clear. On an internal call, the calling extension number should be showing up on the called extensions display. What is the called party receiving? What type (make/models) set is it. Are they all behaving the same?
