Changing CoDec's on a phone
Discussion in '3CX Phone System - General' started by cjammer, Jul 4, 2007.
  1. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    If I changes the CoDec in my Grandstream phone, do I have to change it some where in the 3cx console? Does 3cx auto negotiate the Codec with the client phone?
    I think another thread alluded to this, but I can t seem to find that.
    Is the prefered order...
    GSM
    G.711
    G.711u
    PCM
    Thanks!
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You don't need to configure anything related to codecs. There is only one exception, you may choose set and order of codecs that will be offered to VoIP provider when you make outbound call. For all other cases, automatic negotiation is used.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Hi -
    As a continuation to what SY replied, the preferred order is the following
    G711u
    G711a
    GSM
    The 3CX phone system supports two more types of codecs but the above are the most widely used.
    Nik
  4. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    In the GXP-2000 the codecs listed are:
    PCMA
    PCMU
    GSM
    G.723.1
    G.726-32
    G.729A/B
    Is the PCMU and PCMA the same as G.711U and G.711A?
  5. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    ""Is the PCMU and PCMA the same as G.711U and G.711A? ""
    Hi roger - Yes
    The PCMU and PCMA are the same as G711 U and G711 A (just different names)
    nik
