Changing Default Voicemail Number from 999
Discussion in '3CX Phone System - General' started by turk, Nov 21, 2007.
  1. turk
    Nov 7, 2007
    6
    Is there any way of changing the default voicemail number from 999 (which is the emergency services number in the UK, aka 911/121) to something else?
    Many thanks
    Turk
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    This option at General > General Settings > Voicemail settings ....
