Changing Destination In recording list
Discussion in '3CX Phone System - General' started by RyanF, Feb 8, 2018.
  1. RyanF
    Jul 4, 2017
    41
    Hi Guys
    Is there a way to change the way the destination shows under the recordings tab? When looking through the recordings, when a call has been "Pickup a call" dial code is used to grab a call ringing at another extension. Under recordings it shows the Dial code *20* instead of the actual source number
    can we change this to show the source number?
    Also, when clicking on "date" to organize recordings by date. Nothing changes.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,352
    535
    Hello @RyanF
    I am afraid this cannot be changed when using *20* as there is a re-invite sent from the extension that is trying to pick the call up to *20* in order to pick the call up.
    This is a known issue in SP2 but it has been resolved in the just released SP3.
