Changing Digital Assistant remotely without a remote ext.
Discussion in '3CX Phone System - General' started by earthwing, Dec 8, 2013.
  1. earthwing
    Sep 14, 2010
    20
    I have a customer (school) that needs to call from a home telephone or mobile into the 3CX system and change the digital receptionist. This is a critical need because snow and fog requires the administrators to change a message to advise parents and staff of late starts or class/school cancellations. The uses do not want a 3cx extension on their personal mobile phones.
    They do not have broadband so I cannot provide a remote extension. Is there a way I can accomplish this?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Re: Changing Digital Assistant remotely without a remote ext
    If you/the user are remoting into the pbx simply select the extension you will have the call go to and put in the persons cell phone number whom will make the recording and check the box to ring mobile number simultaneously they will then be able to record the new digital receptionist prompt from their cell phone. Or that person can add 3cx softphone to a computer/laptop and only open when it is needed if they arent also against that.
