changing extension greeting
Discussion in '3CX Phone System - General' started by pat71, Apr 21, 2016.
  1. pat71
    Mar 17, 2016
    44
    Any one knows how to change the extension greeting file for the presence busy for example using API.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    The greeting of an extension is actually not manipulated through the API but by XML files located in C:\ProgramData\3CX\Instance1\Data\Ivr\Voicemail\Data\XXX where XXX is the extension number.
    If no files are found in this folder or if it doesn't exist then it's the default prompt that applies.
    If however there is a file named "greetings.xml" with following contents as long with a wav file matching in same directory then a custom prompt applies for all profiles:
    <?xml version="1.0" encoding="utf-8" standalone="yes"?>
    <overrides>
    <greeting profile="default" file="Yourfile.wav" />
    </overrides>
    If you need separate greetings for certain profiles you may make a test extension, configure it as wanted through the management console, then check the XML file generated.
