Changing FQDN and generate/import SSL Certs for new FQDN
Discussion in 'Ideas' started by ITW, Mar 16, 2018.
Changing FQDN and generate/import SSL Certs for new FQDN 5 5 2votes
5/5, 2 votes
Tags:
  1. ITW
    ITW
    Sep 20, 2017
    22
    I would be glad if 3cx world support changing the FQDN after the installation.
    This requires also to use a new SSL cert afterwards.
    Think of merging companies, or renamed companies or a company changed their domain with another fresh tld.
    For example:
    Company super .ltd decided to use one of the new tld domains and change their domain from super-ltd.com to super.ltd .
  2. timmbo
    Aug 25, 2017
    99
    47
    also it would be great if i can chosse at the Installation "Generate Own Certificate" or "Generate 3CX Domain Certificate" and if i choose Own i put all my company Information including the FQDN and it generates my own certificate on the Installation.
    Because it has to be generated on the PBX itself because the IP has to be right.
    Bye
    Timm
