Changing internal IP of server
Discussion in '3CX Phone System - General' started by jofer, Aug 7, 2017.
  1. jofer
    Dec 5, 2012
    45
    Hi There
    I have a very large V15 system on Windows server.
    I am moving the server into a DC enviroment and the server internal IP has to change.
    Is this possible? and how?
    If the IP has changed how will the devices register to this "new" IP assigned to the server?
    Regards
    Johan
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @jofer
    The only way to change the local IP address of the PBX is to perform a backup without including licence and FQDN information. Then re-install the system using the backup you created. Make sure you save the backup to a non 3CX location before you un-install the system.
    If the phones are registered using the local IP of the PBX you will need to re-provision them. If you have used a local dns with a local FQDN then you need to change your local DNS entry to point to the new IP
  3. jofer
    Dec 5, 2012
    45
    Thank you.
