Changing On-Hold Music.
Discussion in '3CX Phone System - General' started by andykeen, Sep 13, 2010.
  1. andykeen
    Aug 12, 2010
    54
    Hi All.
    Is it possible to change the 'On-Hold' music for the 3cx system?
    Thank you
    Regards
    Andy.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Yes. In V9 you can even have 5 different types to play randomly.
    Go to Settings > General and on the General tab you can choose them.
  3. andykeen
    Aug 12, 2010
    54
    Hi abc123.
    Thanks again - I even looked here and did'nt see it in front of my eyes........
    Best Regards
    Andy
  4. abc123
    Nov 9, 2009
    712
    By the way.
    We find the best results for recording new wav files for 3cx is to use Audacity (it is free).
    http://audacity.sourceforge.net/
