Changing Outbound called ID
Discussion in '3CX Phone System - General' started by pat71, May 4, 2016.
  1. pat71
    Mar 17, 2016
    44
    Hi all,
    I call from one extension to another extension using API pbx.TransferCall is there a way to change the displayed number for the extension that will receive the call. that is change the caller ID using the API.
    Any genius coder available in this part of the web?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    I'm afraid the TransferCall method refers to calls by their ActiveConnection IDs. The ActiveConnection class contains properties with caller details but those are in read-only access thus can't be rewritten by code.
