Solved Changing password for all extensions
Discussion in '3CX Phone System - General' started by big.LITTLE, Feb 28, 2018.
  1. big.LITTLE
    Feb 1, 2018
    14
    Hi guys,
    If I'm going to change password of all of my phone extensions, what is the best way to do it?
    Our phones were provisioned using auto-provisioning, I just want to keep the way 3CX can manage the phones from the 3CX management console (i.e. reboot, reprovision, etc.)
    Please advise. Thank you.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    Under extension, select the required extensions and click on the 'Regenerate' tab then Under Phones select the same extensions and click on 'Reprovision' tab
    If you have any 3CX Clients, IOS and Android devices, you will have to resend the welcome email which will contain the new password
    big.LITTLE and YiannisH_3CX like this.
  3. big.LITTLE
    Feb 1, 2018
    14
