Changing Regional Settings to Hebrew - causes an error
Discussion in '3CX Phone System - General' started by danavni, Dec 5, 2010.
  1. danavni
    Dec 5, 2010
    16
    on windows 7, i set the regional settings like the following:
    Format: Hebrew
    Locale for non unicode programs: Hebrew
    on the latest pbx version (sp4) when going into the Configure work hours you get an exception when trying to open the work hours dialog and the current time is 11:39 a.m
    Error: The DateTime represented by the string is not supported in calendar System.Globalization.GregorianCalendar.
    Stack Trace: at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles)
    at System.Windows.Forms.DateTimePicker.set_Text(String value)
    at WebGuiInterface.BaseForm.TranslateControl(Control control, Control baseControls)
    at WebGuiInterface.BaseForm.OnLoad(EventArgs e)
    at WebGuiInterface.SetUpSpecificHours.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    when the dialog does appear all hours appear reversed (i.e. mm:hh so 11:39 is displayed as 39:11)
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Changing Regional Settings - causes an error
    Hi, Yes this is a known issue - it will be fixed.
    In the meantime use normal settings. We will provide a fix for this.
