Changing SIP Port to 5090 server goes OFFLINE ?
Discussion in '3CX Phone System - General' started by mahesh2k4, May 28, 2008.
  1. mahesh2k4
    May 20, 2008
    Hi everyone,
    I Need SIP Communication packets in TCP format so Iam changed SIP Port to 5090 but the server monitor status goes offline. please tell me how to setup 3CX server in order to send packets in TCP format?
    Regards,
    Mahesh
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Currently, PBX can and will accept TCP connections for SIP communications with no relation to port it uses. Outgoing TCP connections will not be established in normal cirumstances (yes, there's exceptions but it is too complex to explain it here). Moving it to port 5090 will not help. When changing SIP port make sure it is not taken by some other application. For example, 5090 most probably taken by 3CX Tunnel. 3CX PBX can not run if specified SIP port is not free on its start.
