Changing softkey in dialling mode via phone template
Discussion in '3CX Phone System - General' started by Simon4acre, Jan 3, 2018.
  1. Simon4acre
    Mar 2, 2014
    7
    We changed the Send button to GPickup in the version 14 template as below, we do exactly the same after upgrading to Ver 15.5 and it does not work, any ideas where to start looking would be appreciated.
    phone_setting.custom_softkey_enable = 1
    And
    custom_softkey_dialing.url = http://192.168.1.230:5000/provisioning/n91d4zszr9/dialing.xml
    then adding the dialing.xml to the provisioning folder
    <Dialing>
    <Disable>
    <Key Type="Empty"/>
    <Key Type="History"/>
    <Key Type="Switch"/>
    <Key Type="Line"/>
    <Key Type="Favorite"/>
    <Key Type="Send"/>
    <Key Type="DPickup"/>
    <Key Type="Retrieve"/>
    </Disable>
    <Enable>
    <Key Type="GPickup"/>
    <Key Type="IME"/>
    <Key Type="Delete"/>
    <Key Type="Cancel"/>
    </Enable>
    <Default>
    <Key Type="Send"/>
    <Key Type="IME"/>
    </Default>
    </Dialing>
