- Joined
- Feb 2, 2016
- Messages
- 1
- Reaction score
- 0
Basically, I'm looking for a way to change, and indicate the status of a user on the handset.
I understand that normally this is done by 3cxphone - that feature works great - however I'm not keen to use it as I don't want to give the users access to the presence screen without being able to lock out the reception/manager/wallboard screens (the user screen would be fine).
I can setup the keys on the T46 to change status by dialing *30 etc, however the lamps do not latch on the status - i.e. you cannot tell by looking at the phone which status you are currently using. The same goes for changing via voicemail.
Has anyone found a way to indicate the current users status on the T46 handset?
Thanks!
Thanks!
