changing tha paging sound
Discussion in '3CX Phone System - General' started by Bogdan, Jul 21, 2011.
  1. Bogdan
    Jul 21, 2011
    10
    I thought that maybe it was one of the wav's in the Ivr\Prompts\Sets folders, but it isnt.
    Anyone have any idea how?
  2. tsteffens
    Jul 14, 2011
    85
    I would also like to know this, some clients on our old PBX key systems can turn off the paging sound all together so it would be nice to be able to disable it.
  3. willow
    willow Member
    Mar 1, 2011
    471
    there is a beep in the sets folder but it sounds alot like the voicemail beep as well. I am not sure if that is it or not.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Yes, it is "beep.wav"
    There are few "side effects".They will be "exterminated" in the next update.
    If you change "beep.wav" file manually, you need to restart "conference service".
  5. tsteffens
    Jul 14, 2011
    85
    can you please explain "side effects"?
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    "new sound" may appear in few other places but even it is fixable...
  7. Bogdan
    Jul 21, 2011
    10
    replacing beep.wav and restarting the service worked, thanks
