Changing User ID Extension Windows Phone
Discussion in '3CX Phone System - General' started by petewatterschats, Apr 4, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    If I want to change the User ID on an extension, do I need to send another email, and run it at the station
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    Have you tried that? Should would work fine.
    I do that if I want to do some testing using an alternate extension in instead of my primary.
