Changing Voice Mail Menu Extension System Number
Discussion in '3CX Phone System - General' started by benriley, Sep 28, 2010.
  1. benriley
    Sep 28, 2010
    6
    Can you change the Voice Mail Menu Extension System number and if so how?
  2. jsadan
    May 3, 2010
    91
    Login to your 3CX Management Console.
    1. Click on settings
    2. Click on general
    3. Bottom box Voice Mail Menu
    This will allow you to change the number of the Voice Mail Menu Extension Number
  3. benriley
    Sep 28, 2010
    6
    I tried that but it seems I need to add another System Extension for voice mail and I don't know how to do that.
  4. jsadan
    May 3, 2010
    91
    Click in the Systems Extensions Status tab and see if you have a SpecialMenu extension.
  5. benriley
    Sep 28, 2010
    6
    They are no tabs for changing special extensions
  6. jsadan
    May 3, 2010
    91
    What version of 3CX are you currently running?
  7. benriley
    Sep 28, 2010
    6
  8. jsadan
    May 3, 2010
    91
    Should already have the voicemail extension and able to change it with the directions I have given. Only issue I had while testing 3CX 8 free version was the MWI. Depending on how many digits you are using I believe the default is 99 (for 2 digit extension) for 3 digit 999 I would think.
