Cheap USB phone for 3CX?
Discussion in 'Windows' started by Anarethos, Mar 7, 2008.
  1. Anarethos
    Mar 7, 2008
    Hi all!
    Is there any cheap Usb phone that works with 3CX VoIp client (dialing with the keypad, maybe a called-id on the phone itself, but not needed) that is slim enough to carry with my laptop?
    I don't like head-phone and I dont want to carry a ATA device.
    thanks!
  2. Cjay
    Cjay New Member
    Feb 24, 2007
    203
    5
    I use a cheap USB handset originally sold for Skype. Ok, so none of the keys work (as the driver was Skype specific), however if you just use it as a generic USB audio device it works fine. In 3cx Voip client you need to select the correct 'Multimedia device' under File/Preferences.
    Cjay.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    you kan use a TIPYEL usb Phone. hier you have a link:
    http://www.tiptel.org/fr_top.asp?lang_id=2&mid=1202&pid=1202
    if you have bluetooth on your laptop you kan use an JABRA headset. it's also very easy. you have no dialpad, but...
  4. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    We do have a USB phone but we are still awaiting final release of 3CX client so we can have USB Phone keys working with the 3CX client.
  5. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    all right
    i was to quikly. i understand
