Check another persons mailbox?
Discussion in '3CX Phone System - General' started by Tularis, Sep 29, 2010.
  1. Tularis
    Apr 12, 2010
    16
    Hey,
    I have an extension that I would like to be able to check the Voicmail box on, but using my phone logged in as me.
    Is there a way to do this?
    10,781
    287
    Since I turned on the PIN number requirement for VM, I can tell you that when you are asked for the mailbox PIN, press # and you will be asked for a mailbox number, then PIN. It would seem odd (actually, a big security problem) if you could get into anthers mailbox without a PIN, so I suspect that unless you have that option turned on then you won't be able to check messages on any other mailbox.
