Check Server/Desktop Uptime, Offer Windows Update and Reboot Capability of Server/Desktop
Discussion in 'Ideas' started by kinetix, Mar 19, 2018.
Check Server/Desktop Uptime, Offer Windows Update and Reboot Capability of Server/Desktop 5 5 3votes
5/5, 3 votes
  1. kinetix
    Jan 7, 2010
    26
    It would be great, from a support perspective, as a Platinum Partner, to be able to (using the Management Console) Check Server/Desktop Uptime and to Offer Windows Updates and Reboot Capability of the Server/Desktop.
    Gavin Hill likes this.
