Check the operation of 550 Jabra Dial
Discussion in '3CX Phone System - General' started by chikara sugiyama, Aug 12, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hi there
    We verified the "Jabra Dial 550" currently.
    Call is no problem, but in cooperation with 3CX client does not work dial pad.
    Off-hook and on-hook does not work with Jabra.
    OS is Windows8.
    Do you have any work experience someone?
  2. AndreasA_3cx
    AndreasA_3cx Guest
    Hello there and thank you for contacting us.
    Kindly note that Jabra devices are unsupported by 3CX, but you can try assigning the Jabra device as the default audio and microphone device in the 3CX Phone and the windows.
    Kind Regards
