Check VM
Discussion in '3CX Phone System - General' started by jpillow, Mar 12, 2013.
  1. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    How can I dial into my 3cx system and check vm when I'm away from the office???? should be easy enough though I've never had to do it before. :S
    11,117
    329
    You have to be able to reach the VM system (999), perhaps through an option in an automated attendant, or a dedicated DID/phone line, then enter the desired extension and PIN. Unfortunately, there is not yet a way to access your messages when calling into your own line,then interrupting the outgoing message,as there is with basic answering machines.
    I've tried, in the past, getting that added as an option.
