Check wake up calls
Discussion in 'Windows' started by MarkLilly, Jan 15, 2018.
  1. MarkLilly
    Oct 21, 2016
    6
    I have rolled out 3cx into a hotel. (70 room extensions)
    The receptionists set the wake up calls for the rooms using the webclient.
    If the receptionist wants to double check that she has set the wake up call, is there any way she can do this via the web client or any other way?
    Cheers
    Mark
  2. jed
    jed New Member
    Feb 1, 2010
    133
    37
    In the WebClient you can go to the Switchboard, and click on the Reminders. Here you will see active reminders (VakeUpCalls)
  3. MarkLilly
    Oct 21, 2016
    6
    Many Thanks Jed, thats perfect!
