Choose from multiple SIP Trunks
Discussion in '3CX Phone System - General' started by yourcourses, Jan 12, 2016.
  1. yourcourses
    Jan 12, 2016
    I have 3CX setup with multiple SIP Trunk providers; I would like to be able to choose which one to dial out from.
    I can change which one is the default and the backup Routes; but I want to be able to select which one to dial out from from my handset.
    I have Yealink t46Gs.
    Thanks in Advance.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    is there a reason why you have multiple SIP Trunks?
    you would need to had a prefix to each outbound rule such as 9 for Trunk 1 and 8 for trunk 2.
    you would then dial 9<Phone Number>
