choose to receive internal but not external calls.
Discussion in 'Ideas' started by fabien114, Jun 23, 2017.
choose to receive internal but not external calls. 5 5 50votes
5/5, 50 votes
  1. fabien114
    Jun 23, 2017
    Ability to customize a status so that you can still choose to receive internal but not external calls.
    We want to be able to make a call forwarding for external calls but be able to be reached internally
    PS : sorry for my english, i'm french.
    #1 fabien114, Jun 23, 2017
    d.blum likes this.
  2. d.blum
    Oct 13, 2015
    9
    This would be a great feature.
    We have the problem, that our phones are going to DND outside of business hours, but we want to do internal calls.
    The way over the incoming rules is not possible, because an employee must have the choice to receive also external calls when he switch back to available.
  3. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    As far as i know, this is already possible.
    Just go to the forwarding rules for your extention, then edit the different states like "away" "DND", etc.
    The handling of internal and external calls here is done seperately.
    I am not really sure, if it is possible to do an unattended handover, but at least with attended handover it should work (because it would initiate an internal call first)
  4. d.blum
    Oct 13, 2015
    9
    It's not possible.
    In the forwarding rules for DND I can't say "Accept" for internal calls, only forward to extension/viocemail/number etc.
    fabien114 likes this.
  5. fabien114
    Jun 23, 2017
    it's exact
    That's what I'm asking
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    This has been requested in other threads and is absolutely necessary.
    +1
    Silly English Kniggit likes this.
  7. Andrzej Pierscionek
    Jul 6, 2017
    14
    I've had the same problem. Fortunately I needed this for only 2 extensions, so I directed their DDI to queue with one member. If they don't want external calls than they log out of queue.
    But this will work in small scale. This would be useful feature.
    Some clients do ask about this.
  8. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Come on 3CX staff. Please make us happy!
  9. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    Did you try the "Available 2" Status? Its pretty much the same as available.
    But i agree, it would be more handy if you could set it all on all states
  10. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Would not help. The problem is:
    When You decide to make a forward rule for external calls then You MUST also create a forward rule for internal calls.
    It is not possible to make a forward rule to your own extension. So there is no way to make your own phone ring when you have a forward rule.
    Try it.
  11. jeroendebruijn
    Nov 9, 2015
    35
    18
    I wonder if this is possible:
    allow all incoming calls , but configure exceptions of the forwarding rules
    allow calls form caller ID XXXX* (all numbers > 999 if your extensions are 3 characters, X means 1 character, * means 0 or more characters) )
    Received during out of office hours | Specific hours
    forward to : end call | Voicemail | Queue
    3CX v14 as well as v15 both accept these rules, but i am not able to test it sadly
  12. Joe W
    Apr 10, 2017
    17
    5
    Yes there is.
    [​IMG]
  13. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Okay, I did not explain correctly: You CAN place a forward rule to yourself. But it will not work. It will make 3CX Say: "Please contact Your administrator..."
  14. nitrox
    nitrox New Member
    Sep 10, 2016
    102
    11
    it is an important feature for us as well so we kindly ask to implement it.
  15. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Thank You for supporting!
  16. Silly English Kniggit
    Sep 13, 2017
    220
    90
    Yes - ALL those options should allow "receive call" as an option. This causes us integration / user acceptance issues.
    Nomen Nominandum likes this.
  17. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Thank You Silly for support!
  18. aws2p
    Jan 9, 2014
    55
    6
    +1 want to have this also
  19. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    did you vote? Still 21 votes...
  20. Brian Buell
    Aug 9, 2017
    36
    5
    +1
    Yes, this is an important feature for many of our customers.
    Allow Internal, Forward External or inbound calls from RGs
