Chopped Voice
Discussion in '3CX Phone System - General' started by pangasewa, Apr 4, 2008.
  1. pangasewa
    Apr 4, 2008
    Hi, Since we started using 3cx we have been having issues such as sometime we are getting voice being chopped out from internal calling but also if inbound call coming in. We have made some changes to our configuration after Patton team suggested what we need to try but the problem still exist. it happens more when we connect atleast more than one PSTN line to the Patton Gateway.
    We are using 3cx free version and we have patton 4114 and on the phones we have a mix of snom320 and grandstreams 2000. We are not using any Voip provide, its just normal PSTN line from the bell company.
    we have taken out the codec g729 and leave G711 per recommendation from Patton team.
    please send us you comments that may help us solve this issue, we have spent quite number of days without an answer and we are thinking of pulling out from this project.
    here is our configuration
    webserver port 80 language en
    system
    ic voice 0
    profile ppp default
    profile call-progress-tone US_Dialtone
    flush-play-list
    play 1 1000 350 -13 440 -13
    profile call-progress-tone US_Alertingtone
    flush-play-list
    play 1 1000 440 -19 480 -19
    pause 2 3000
    profile call-progress-tone US_Busytone
    flush-play-list
    play 1 500 480 -24 620 -24
    pause 2 500
    profile call-progress-tone US_Releasetone
    flush-play-list
    play 1 250 480 -24 620 -24
    pause 2 250
    profile call-progress-tone US_Congestiontone
    flush-play-list
    pause 2 250
    profile tone-set US_default
    map call-progress-tone dial-tone US_Dialtone
    map call-progress-tone ringback-tone US_Alertingtone
    map call-progress-tone busy-tone US_Busytone
    map call-progress-tone release-tone US_Releasetone
    map call-progress-tone congestion-tone US_Congestiontone
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    profile voip fax_enabled
    fax transmission 1 relay t38-udp
    profile pstn default
    profile sip default
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface eth0
    ipaddress 10.7.1.111 255.255.255.0
    context cs switch
    no digit-collection timeout
    interface sip sipif0
    bind gateway sipgw0
    service default
    route call dest-service fxohuntgroup
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    interface sip sipif1
    bind gateway sipgw1
    service default
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
    interface sip sipif2
    bind gateway sipgw2
    service default
    address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
    interface sip sipif3
    bind gateway sipgw3
    service default
    address-translation outgoing-call request-uri user-part fix 10003 host-part to-header target-param none
    interface fxo fxoif0
    route call dest-interface sipif0
    disconnect-signal battery-reversal
    disconnect-signal busy-tone
    dial-after timeout 1
    use profile tone-set US_default
    interface fxo fxoif1
    route call dest-interface sipif1
    interface fxo fxoif2
    route call dest-interface sipif2
    interface fxo fxoif3
    route call dest-interface sipif3
    service hunt-group fxohuntgroup
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    drop-cause user-busy
    route call 1 dest-interface fxoif0
    route call 2 dest-interface fxoif1
    route call 3 dest-interface fxoif2
    route call 4 dest-interface fxoif3
    context cs switch
    no shutdown
    gateway sip sipgw0
    bind interface eth0 router
    service default
    domain 10.7.1.127
    authentication 10000 password 10000 default
    default-server 10.7.1.127 loose-router
    registrar 10.7.1.127
    user 10000
    gateway sip sipgw0
    no shutdown
    gateway sip sipgw1
    service default
    domain 10.7.1.127
    authentication 10001 password 10001 default
    user 10001
    gateway sip sipgw1
    no shutdown
    gateway sip sipgw2
    service default
    domain 10.7.1.127
    authentication 10002 password 10002 default
    user 10002
    gateway sip sipgw2
    no shutdown
    gateway sip sipgw3
    service default
    domain 10.7.1.127
    authentication 10003 password 10003 default
    user 10003
    gateway sip sipgw3
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    no shutdown
    port fxo 0 0
    use profile fxo us
    encapsulation cc-fxo
    bind interface fxoif0 switch
    no shutdown
    port fxo 0 1
    use profile fxo us
    bind interface fxoif1 switch
    no shutdown
    port fxo 0 2
    use profile fxo us
    bind interface fxoif2 switch
    no shutdown
    port fxo 0 3
    use profile fxo us
    bind interface fxoif3 switch
    no shutdown
    thanks
  2. msauer
    Mar 15, 2013
    10
    We have similar issues but not as many as before this change-
    Made sure that all Gateways and other phones use G711u first. As the Patton gateways only have 3 codecs available, our first in the list is G711u then G711a then G729 in that order, I didn't remove the G729 just moved it to the bottom. The phones also are PCMU first which I understand is G711U. In 3CX the codecs seem to be able to be set under the provisioning tab, but because Grandstreams are not fully supported anymore, I set this in the phones themselves. I figure that the least searching in a list of matching codecs may ease the connections. G729 has been shown at our place to have poor quality and it seems after about 3 to 5 minutes becomes worse. I am still searching for the perfect cure to this problem but this has definitely helped.
