- Joined
- Jul 23, 2012
- Messages
- 27
- Reaction score
- 0
Hi all,
I just set up a new VPS located in Toronto like myself, Windows Server 2008 with 2GB ram and 1 core. Running on 100mbps fibre. Installed 3CX on it but having issues with call quality internally and externally. It keeps cutting off the odd part of words, like "Hi there h-w are you doi-g toda?"
I tried from IP phones and the 3CX soft phone. They are all remote extensions, register no problem and make calls no problem. I've read lots of threads on here with similar issues but everyone keeps talking about try a different network card, or bios settings etc but this is a VPS I can't just change those things.
Like I call 999 to access voicemail and it's like "P-p-lease enter ersonal identification umber and then ress pound".
If I'm using a VPS I don't have access to the router etc so is it necessary to prioritize voip and so on? When I use asterisk I don't have to do that I just install it and use it. Was just about to uninstall but thought I'd try one last time here. Thanks.
