Choppy Music on Hold but not on Park
Discussion in '3CX Phone System - General' started by rx7boy, Feb 22, 2012.
  1. rx7boy
    Jan 1, 2012
    Hello
    We have recently installed 3cx and some panasonic VOIP phones. We are having a strange problem which I could not really find an answer for on the forum. When we answer a call on the panasonics and want to blind transfer them is when it happens. So when we press the blind transfer button the music on hold is very choppy then as soon as it parked the music go normal for the listener. Anyone have any ideas what causes this? Would changing the format of the audio file in anyway help?
    John
    Boylan Imaging
    10,752
    285
    Have you confirmed that both "musics" are from the same source? Some phones, depending on what action you are taking, can provide their own music. Is the music, the same tune?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Select all extensions which are handled by Panasonic phones. press "Edit Extension" button at the top of the list. Then on "Other" tab tick "PBX delivers audio". Press OK at the bottom of the page.
    Does it resolve the problem?
    Which model of Panasonic phones are you using?
  4. rx7boy
    Jan 1, 2012
    Hello
    I know this is a bit old now but this did fix my problem by selecting "PBX delivers audio" option. We are using the Panasonic KX-TGP550's and now I have one more problem but not sure if I should create a new thread for this.
    We have 3 lines vis pstn and when we put someone on park via the blind transfer, then if we park another call via blind transfer so we now have 2 calls on park if someone tried to pick up the parked 1st parked call it will send the parked call to voicemail. Hopefully this makes sense. What setting would or should fix this? I can't seem to see what would be causing this.
    Thank you
    John Boylan
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    Are you using * parks or Shared Parks?
    Could you program SP's to BLF Buttons?
  6. rx7boy
    Jan 1, 2012
    It looks like we are currently using * parks, how do we actually use the shared parks? When we are blind transfering someone how do we put them on a shared park rather than a * park?
    John
  7. craigreilly
    Feb 1, 2012
    3,321
    252
    Some phones allow SP0, SP1, etc to be used as a 1 button pickup/release.
    We have 5 parks on our Yealinks. We do not actually transfer there - we just hit the button to put the caller there, then hit it again to pick it up.
    There is an option in the setup for # of Shared Parks (I think up to 30 in v11)
