- Joined
- Oct 11, 2007
- Messages
- 30
- Reaction score
- 0
I'm setting up a new system and am having some problems with choppy sound. Here's a test case.
I have a VoiP lin setup with InPhonex in 3CX.
I have a softphone on a laptop.
My 3CX server is setup at a data center.
I'm sitting in my office with my laptop far away from my data center.
The softphone registers. Then, I dial my landline. Then, I pick up the land line and then put the call on hold from my softphone. The music plays. But it's choppy. Very, very, very, choppy.
Here's the call log:
07:52:42.636 StratLink:nHangUp [CM104001] Call(80): Ln:10000@InPhonex hung up call; cause: BYE; from IP:208.239.76.163
07:52:35.876 MediaServerReporting::RTPReceiver [MS005001] Call(80) Ext.201: payload #126 doesn't correspond initial SDP datalen=4
07:52:25.351 MediaServerReporting::RTPSender [MS004000] Call(80) Ext.201: (ACTIVE): Can't send RTP stream to 0.0.0.0:60390 destination unreachable
07:52:24.049 CallLegImpl:nConnected [CM103001] Call(80): Created audio channel for Ln:10000@InPhonex (208.239.76.163:64800) with Media Server (209.97.223.104:9200)
07:52:23.999 StratInOut:nConnected [CM104005] Call(80): Setup completed for call from Ext.201 to Ln:10000@InPhonex
07:52:23.989 CallLegImpl:nConnected [CM103001] Call(80): Created audio channel for Ext.201 (71.114.254.84:60384) with Media Server (209.97.223.104:9198)
07:52:17.880 CallConf:nProvisional [CM103003] Call(80): Ln:10000@InPhonex is ringing
07:52:15.958 CallConf:nIncoming [CM103002] Call(80): Incoming call from 201 (Ext.201) to sip:[email protected]
