Chrome Extension - 3CX Click-to-call
Discussion in 'Ideas' started by npereira@cbnco.com, Aug 17, 2017.
Chrome Extension - 3CX Click-to-call 5 5 1votes
5/5, 1 vote
  1. npereira@cbnco.com
    Sep 21, 2012
    32
    12
    hello,
    I installed the 3CX click to call extenison in Chrome. It works, but the number that comes up does not have our leading digit to make outbound call.
    Is there a way to add this in any way? Or does the user have to always insert the 9 in front of the number?
    Would be nice for this to be somehow programmable.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Thank you for the suggestion.
    We will add an option to have leading digit.
    jj1 and Marika3CX like this.
  3. jmatano
    May 31, 2018
    29
    Is this still planned to be rolled out? We would definitely use this, but I'd really like to not open 10 digit dialing without a prefix.
  4. LeonidasG
    Nov 19, 2008
    1,557
    118
    This will be available in a future release of the plugin.
  5. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    For now, couldn't you simply create an outbound rule that accepts calls that don't have the leading digit? In my personal opinion, and many may disagree, requiring an extra digit to make an outbound call is an archaic approach that is no longer needed in most cases.
