chrome webrtc
Discussion in '3CX Phone System - General' started by donbru01, Oct 28, 2015.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all, from few day on my webrtc if i use chrome when make call i return
    Failed . If i use firefox all work fine .
    If i go on 3cx site and i try to connect to contact via clictocall i have same issue
    Suggestion?
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    remember reading that the latest Chrome update broke 3CX webrtc
  3. argenvoip
    Sep 19, 2011
    14
    Hello (not speak English I use the translator) 3cx and technicians solved the problem after Chrome update. If you need to change the files on your 3cx, I can send you by mail. Send a private message. I received from the technical support
    Greetings from Argentina
    Marcelo
  4. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    I marcelo , thanx so much can hou send me info at bruno.donetti@axitea.it
  5. argenvoip
    Sep 19, 2011
    14
    Hello Bruno, send the zip file to your mail.
    Greeting
