CID (caller id) in a Queue
jspearso
my caller id works fine when i dial the extension directly
but as soon as the outside line from a sip 3000 connects to a queue the caller id then shows up as 10000.
is there a way to fix this
cheers
and thanks in advanced
Josh
To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
https://erp.3cx.com/orderform/support.aspx
regards
Getting Started - Admin
Boykins_54
Get 3CX - Absolutely Free!
3CX
