cid does not display on external call
Discussion in '3CX Phone System - General' started by zeki, Nov 11, 2007.
  1. zeki
    Oct 27, 2007
    11
    Hi, my caller ID does not display when I place external calls. I have set the caller ID no in 3cx but this number does not display on the destination handset?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please provide more details for your issue.
    - 3CX version
    - Type of lines (BRI or PRI)
    - Brand/Model of gateway
    - Gateway debug log
    - 3CX Console log
    Where are you set the calling party ID? Outbound ID? Gateway's Digits Map?
    What "caller ID" set on your 3CX?
    What number display on your called phone? No number or Main number?
    We cannot guarantee to fix your issue. But the above information may be help to fix your issue faster.
