CID Inbound
Discussion in '3CX Phone System - General' started by prest, Mar 22, 2011.
  1. prest
    Mar 22, 2011
    Hi All,
    Is there a way to change inbound Caller id for specific incoming numbers?
    11,277
    360
    Some gateways can add digits to caller ID, and there is/was a caller ID manipulation within 3CX that hasn't been pursued so far. What are you trying to change with the incoming numbers?
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Not quite understand what kind of changes and in what cases do you mean, but may be 'inbound / outbound reformatting' is what you're looking for?
