- Joined
- Oct 11, 2009
- Messages
- 28
- Reaction score
- 0
I set the field from:display number to be the originator CID and with the new verbose log (great feature, thanks for that) I can see that the CID that came in through the pstn gateway is passed on to the outbound invite, forwarding to the mobile.
Unfortunately it contains a leading 0, because that's what you need everywhere else in the pbx. I played around in the "manipulate CID" settings but all I could get was a 49097... instead of a 4997...
Ist there a way to manipulate outbound CIDs on a trunk to simply remove the leading 0 or replace it with a constant? I only found a way to set a prefix, but not to replace a digit. Sipgate wants the format without leading 0 and doesn't accept anything else.
I know it will cause trouble for incoming international calls but those would just come through as the DID anyway.
If there is a way to make 004997... to be 4997... and 097... to 97... it would fix the problem and allow me to send correct extension DIDs to other providers than Sipgate. I thought that "reformat CID" in the trunk settings would do that, but I can't figure out how.
br
Heinz
br
Heinz
