CID to VM on V15
Discussion in '3CX Phone System - General' started by daktur, May 14, 2017.
  1. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    Hi ali,
    In V14 before upgrading to V15 I was able to set an inbound that when the CID was from my mobile to go direct to VM extension 666.
    I had to edit this rule in v15 and suddenly I cannot forward the call straight to VM as done before.
    Was this feature removed from v15? I can only select extensions from a dropdown menu and the system ones are not appearing.
    Any clues?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,830
    565
    Hello @daktur
    You will find the voicemail extension listed under extensions. Make sure you are using a supported browser like google chrome.
