CID transfer problem (PSTN>SPA3102>3CX) (SOLVED)
Discussion in '3CX Phone System - General' started by Halea, Jan 5, 2008.
  1. Halea
    Halea New Member
    Jan 5, 2008
    151
    My PSTN supplier is actually OptimumVoice. When I connect a phone to it I get to see caller's name and phone number. So, OV seems to be OK.
    My SPA3102 is setup with "PSTN to VOIP" enabled and configured with defaults (which seems to indicate that CID transfer from PSTN to VOIP is turned on). When I receive a PSTN call my VOIP phone connected through 3CX shows "SPA-3102" and "10001" as caller's name and number, which I believe are the info that I entered in SPA3102 in the "VOIP Line Registration" settings.
    Other than the CID issue, everything else works fine. Can call in and out with top quality sound.
    I am trying to properly configure so that I get to see the PSTN caller's real name and phone number. Any help will be appreciated.
  2. Halea
    Halea New Member
    Jan 5, 2008
    151
    Re: CID transfer problem (PSTN>SPA3102>3CX)
    After firmware upgrade to 5.1.7 and lots of playing around with settings, I am still at the same point. CID from PSTN is caught by SPA3102 (since it can actually show it at the end of the communication on the infor page), it never gets transfered to 3CX. :cry:
    Halea
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Make sure that on the PSTN Line tab you have PSTN CID to Voip CID enabled....
    Cheers
  4. Halea
    Halea New Member
    Jan 5, 2008
    151
    Finally I solved the CID problem. I setup SPA-3102 with a 5 second delay in picking up the PSTN line when a call comes in. It did the trick. Inserting a delay in 3CX didn't help. :roll:
    Halea
